10.4.7 wireless connection problem?
Discussion in 'macOS' started by azoner, Aug 8, 2006.
  1. azoner macrumors newbie
    Mar 21, 2006
    I can no longer connect either my powerbook or powermac to either of my wireless access points if wep security is used. One router runs wpa, the other has to run wep because that's all the print server can do. To pin this down, I found that both computers can connect to an access point configured wpa. And both can connect if security disabled. But neither can connect with access point setup with wep. Before 10.4.7 I could connect with no problems. Have two PCs running XP that continue to access wireless router using wep security. Anybody having this problem? And any suggestions??
  2. mad jew Moderator emeritus
    mad jew
    Apr 3, 2004
    Adelaide, Australia
    I'd try resetting and maybe reconfiguring the router(s).
Share This Page
