Best Way to Monitor Battery Level
Discussion in 'iOS 6' started by ApolloX, Nov 11, 2012.
  1. ApolloX, Nov 11, 2012
    ApolloX
    Expand Collapse
    Feb 1, 2007
    #1
    I'm developing an iOS that for display reasons requires full screen, but I'd still like to have a battery indicator present on screen for the user.
    One simple solution is to create a timer that updates the battery indicator on screen every X number of seconds such as:
    Code:
    [[UIDevice currentDevice] setBatteryMonitoringEnabled:true];
    [NSTimer scheduledTimerWithTimeInterval:60 target:self selector:@selector(setBatteryIndicator) userInfo:nil repeats:YES];
    Is there a better approach way? Should I be using a notification system to receive notifications every time the battery changes? Anyone have a code snippet that is better than the approach I'm using?
  2. mnemonix
    Expand Collapse
    Jun 23, 2005
Share This Page
