FT: MBP Power Supply Wall Cord for Power Supply Wall Adapter
Discussion in 'Marketplace Archive 2' started by w8ing4intelmacs, Jan 6, 2008.
  1. w8ing4intelmacs
    Expand Collapse
    Feb 22, 2006
    East Coast, US
    #1
    I've been using my MacBook Power Supply with the AC cable but would like to switch to the smaller AC wall adapter. But I can't find that part anymore!
    So, just wondering if there's a MR person out there that would like to trade the long wall cord for the small wall adapter (not including the power supply itself).
    BTW, if someone has a suggestion for wording this better, I would really appreciate it :)
  2. thegoldenmackid
    Expand Collapse
    macrumors 604
    thegoldenmackid
    Dec 29, 2006
    dallas, texas
    #2
    I have one...
    An easier way to phrase this:
    You are giving away the long chord in return,
    The other person gives the short wall adapter.
  3. w8ing4intelmacs
    Expand Collapse
    thread starter macrumors 6502a
    Feb 22, 2006
    East Coast, US
    #3
    thanks. that does seem easier :)
  4. TEG
    Expand Collapse
    macrumors 604
    TEG
    Jan 21, 2002
    Langley, Washington
    #4
    The small plug adapter that fits in the AC adapter is called (by Apple) "The Duckend Connector".
    Your "long cable" is a 2m cable, the ultimate question is... Does it have a grounded (3 prong) plug or a non-grounded (2 prong) plug?
    You were never able to buy the duckend connector as a separate part, it only came with new AC adapters. You can usually find one on eBay for about $1.
    TEG
  5. w8ing4intelmacs
    Expand Collapse
    Feb 22, 2006
    East Coast, US
    #5
    the ones i found on ebay go for $4 + s/h (usually $6), or more. it's definitely a grounded plug (i.e., came from a magsafe power supply).
Share This Page
