G5 Power Tower - no sound outta rear& front RCA jacks
Discussion in 'PowerPC Macs' started by nomadix, Jun 13, 2010.
  1. nomadix macrumors regular
    Jul 3, 2006
    #1
    Hallo All:
    just happened - have my mini stereo plugged into back of my G5 Power Tower Quad - iTunes through to mini stereo
    all of sudden I got no sound - shut computer down - restart I had to reset - restarted and sound again - then sound quit and now no sound period outta front or rear RCA outputs
    internal micro speaker works fine
    Sound card crapped ? anyone have experience
    cheers in advance
  2. Hrududu macrumors 68000
    Hrududu
    Jul 25, 2008
    Wichita KS
    #2
    I'm guessing you've checked to make sure all your sound settings in Preferences are correct? Maybe it switched over to the optical outputs or something? Unfortunately troubleshooting recommends a logicboard replacement if an audio failure occurs. Personally I would do everything possible to make sure it isn't software related. Reinstall Mac OS if you have to. Can you log into another account to see if audio works there?
  3. 666sheep macrumors 68040
    666sheep
    Dec 7, 2009
    Poland
    #3
    You can also try possible resets: PRAM and PMU.
Share This Page
