help me build a Major 15,000+ LED Arduino application project
Discussion in 'Design and Graphics' started by DJPrestige, Sep 25, 2010.
  1. DJPrestige
    Expand Collapse
    Sep 25, 2010
    #1
    I have an empty room and 15,000+ LED's
    the rooms walls are all 94x120 and I'm basically aiming for a visual replica of
    the deadmau5 stage from the VMA's
    Basically what I think is if after I give each LED a unique ID I route the lights
    to its own arduino 1 for each quadrant or so. or if I could route all the LED's to one major board. I have no Idea how to power this project nor do I have any idea how to code such a large visual array to small accurate animations and visualizations. any idea how to incorporate a code converter so maybe I can upload Mpegs and popular video formats to be read by the arduino or microcontroller and thus played via the LED's? :)
  2. lucidmedia
    Expand Collapse
    Oct 13, 2008
    Wellington, New Zealand
    #2
    I don't think the deadmau5 wall is a simple LED hack. It looks to me like a matrix of jumbotrons, which are LED based, but have lots of proprietary circuitry. A 33 ft. x 110 ft. jumbotron costs about 3 million dollars today.
    In terms of "doing it yourself" I think you may eventually run into problems of scale. You need 16 digital outputs to control an 8 x 8 matrix of LEDs... The Arduino Mega has 54 digital I/O pins so you can get at least 3 matrices running on a single board... 192 LED soldered, only 14,808 to go!
    For a wall of that size, do you need that much "resolution"? For example, I have seen quite a few "LED walls" made with a matrix of frosted glass blocks. Each glass block only requires one LED at its center. The light illuminates the whole block evenly. Using a technique like this you would need to use significantly less LEDs, and could probably get away with only using 3 or 4 arduinos.
    How long will this wall be up for? Personally, I usually lean towards projection/projection mapping instead of a huge LED matrix for big installs... if its a short engagement, look into renting a high-lumen projector... or, if you are trying to do this on the cheap, use something like Dan Shiffman's open source "Most Pixels Ever" library (written for processing) so you can stitch a huge visualization across a collection of inexpensive LED projectors.
    http://code.google.com/p/mostpixelsever/
    As for your other question, your digital video is already an array of values so you have lots of options routing that data to an LED matrix... lots of folks use max/MSP/Jitter, many use processing, you could even do it in flash... it all comes down to how you wind up wiring your lights up and the language you are most comfortable programming in.
Share This Page
