Help! Trouble Connecting PS2 to Web Using APE
Discussion in 'General Mac Discussion' started by Col. Panic, Jan 24, 2005.
  1. Col. Panic macrumors member
    Oct 20, 2004
    Connecticut
    #1
    I just bought one of the new slim PS2s with the built-in network adapter and I am having trouble connecting to the internet through my AirPort Express.
    Here's my set up. I have my PS2 connected via ethernet to an AirPort Express behind my entertainment center. I have another AirPort Express in the basement connected via ethernet to my cable router. I am using Comcast for my ISP.
    When I go to ISP setup on my PS2 I select: I have an ISP > Automatic Configuration > Other > Test Settings.
    According to Comcast's FAQ this is all I should need to do.
    Possible problem: I am using an ethernet cable I got from one of the tech guys at work. The little clip that you need to press to release the wire when removing the cable is broken off but I made sure it is securely in the PS2.
    Other than that I am at a loss.
    Should there be any problems using 2 AirPort Expresses in this setup? Or, am I missing something else? I have a feeling I am just missing something really obvious.
    I will try another ethernet cable but I really don't think that is the issue.
    Thanks for your help!
  2. rtdgoldfish macrumors 6502a
    rtdgoldfish
    Jul 4, 2004
    Jacksonville, FL
    #2
    The APE's ethernet port does not work like that. It is only for plugging in a source that provides internet i.e. cable/DSL modem. You can't use it as a wireless adapter for the PS2.
    And if I am wrong about this, please let me know. I have one of the new PS2 units and an APE as well but I don't want to spend $100 for a wireless adapter for the PS2.
  3. Col. Panic thread starter macrumors member
    Oct 20, 2004
    Connecticut
    #3
    It works! All it needed was a reboot of the AirPort Express. I may have jiggered it a bit when I inserted the ethernet cable into the Express. I knew it would be something stupid. I just played a bit of Ratchet & Clank online and got my butt kicked by a bunch of 13 year olds. I was in college before they were born! I feel old.
    I have the new slim PS2 that has the networking adapter built in. So all I needed to do was connect it to the internet via my wireless connection.
    If you have the older PS2 you will need to buy the network adapter.
Share This Page
