Help! wireless problem
Discussion in 'macOS' started by Jenjen, Jul 23, 2006.
  1. Jenjen macrumors newbie
    Jul 23, 2006
    #1
    Hi :)
    I've had some problem with wireless internet, and am hoping to get some advice.
    I bought my macbook pro in early April in Boston.
    I accessed to the internet through a closed network there.
    Then I came to NewYork and stayed in my friend's home for a while.
    There were two friends, one used pc and the other used G4, and both of them connected to an open network whithout any ID of passcode. My macbook pro did it too, at first. However, from the second or third day, the speed became extremely slow, or it didn't catch any signal at all, or, even if it did, the network required a wep key so I wasn't able to access, while my friends' computers were totally able to connect to the same network.
    After that I moved to another house, used cable, and everything was fine.
    Now, I've moved in again, and have the same problem as that in my friend's house. I just can't understand why my macbook pro can't connect to the same network network while others can. Would it be anything about my airport card? I tested the hardware, but everything was ok. My firewall is of course turned off.
    If anybody know the answer, please help me. I'llvery appreciate for it.
    Thank you for reading this long thread!
  2. iTwitch macrumors 6502a
    iTwitch
    Mar 30, 2006
    East of the Mississippi
    #2
    If the network required a WEP key it might be that they entered it once and their systems remembered it. I use WPA but I don't need to enter the key each time I connect.
    The others are able to connect because they are properly configured?
    Try using the Airport Setup Assistant in your apps/utilities folder, I wish I was on my iBook now.
  3. REDSRT4 macrumors regular
    Jul 20, 2006
    #3
    it could be a number of things, sometimes you connect to the wrong network without even knowing it, i have been at friends houses with my PB and accidently connected to others networks without knowing it and it has been very slow!
  4. Jenjen thread starter macrumors newbie
    Jul 23, 2006
    #4
    Thanks!
    Thank you for replying.
    Anyway it's ok now though I don't know why.
Share This Page
