Logic pro midi problem please help asap!!
Discussion in 'Digital Audio' started by preppyclubguy, Jan 29, 2010.
  1. preppyclubguy
    Expand Collapse
    Jul 31, 2009
    #1
    so im tryin to use a few different plugins with logic pro, most work but ones like ik multimedia samplemoog dont. what i mean by they dont is when i open the plugin it opens fine if i use my mouse to either play notes on the plugin its self or the midi sequencer it sounds,,, but now when i try to play it with my midi keyboard i dont get any sound , the notes show up on my midi arrange window but there seems like to stream of data going to the plugin now, like i said if i draw the notes in it works fine,,,, any ideas please help this song is due by tomorrow
  2. spinnerlys
    Expand Collapse
    Guest
    spinnerlys
    Sep 7, 2008
    forlod bygningen
    #2
    What Mac, what midi keyboard, what version of Logic, Mac OS X and plugins are you using?
    The thread title guy strikes again:
    Also a more descriptive and precise thread title will help cater to the right audience and get you more responses.
    To edit your thread title, just click on the [​IMG] button on the bottom right of your original post and then click the "Go Advanced" button below your message.
    Have you also taken a look at MRoogle, since that question may have been asked already?
    Example: Logic (Pro) version 999 does not play a sound via Midi Input with the ... plugin or something like that. please help!!! is not really helping you.
  3. preppyclubguy
    Expand Collapse
    thread starter macrumors member
    Jul 31, 2009
    #3
    imac 3.06, logic 9.02, ik multimedia products as well as korg products
  4. deej999
    Expand Collapse
    Apr 1, 2009
    #4
    what MIDI channel is your keyboard output and is the Instrument track set to receive MIDI on that channel? Look in the Inspector.
    deej
  5. sobrenadar
    Expand Collapse
    Apr 22, 2011
    #5
    I am having the same problem!!!!!
    please help :(
Share This Page
