MacRumors
macrumors bot
Apple offers two versions of the AirPods 5: a $129 model with a USB-C Charging Case and a $149 model with a Wireless Charging Case. The extra $20 also buys longer battery life, swipe volume controls, and additional Find My features, so there are differences between the earbuds themselves as well as their cases.
  • Haha
Reactions: Z-4195
I was using some 3rd party usbc earbuds with my iPhone and I noticed the lowest volume setting is a bit too loud. Is that issue something that will occur with official Apple usbc EarPods as well? Or is that an issue only with 3rd party usbc earbuds? I also noticed the middle button doesn’t do double click to advance to the next track. Again I’m wondering if that’s an issue with 3rd party usbc earbuds or also Apple usbc EarPods.
The cases aren't interchangeable? So the earbuds are different too?
Looking at the Apple support page linked in the article it does appear to be the case. The non-wireless case buds have different model numbers. Given the wireless charging case ones have longer battery life, I’d guess they have slightly larger batteries inside. Still, you’d think there would be no reason to prevent upgrading later.
Reactions: jacobgkau
Agree. I can't even fathom a scenario where someone has the means/budget for a $100+ pair of earbuds but can't swing the extra $20. It's ridiculous they made the cheaper model at all and just creates confusion for buyers.
They will be the model that goes on sale more often. People who were going to buy the pro will get the pro with wireless charging case, but people who weren't going to buy the pro will get the cheap-pro version if it's just a few dollars more.
And Apple has once a gain diluted their branding for an extra buck.
This is not about selling you the airpods 5 wireless charging case model, but upselling you to the airpods pro 3. Had there only been one model for $129 the difference is too much to upsell.
The wireless charging version charges with the same wireless charger my Watch uses and that makes it very convenience to charge at nighttime. I can put it on my Watch charger and it's will magnetically attach whereas having dangling charging cables [while isn't totally inconvenient] makes my night stand a mess.
Reactions: citysnaps
After being spoiled with the comfy ear tips of the Pro series, I don't think I could go back to that hard plastic again. I hope those who can enjoy them do enjoy them, though.
Reactions: SFjohn
If the only difference b/w the two versions was simply wireless charging, I could see it be worth saving $20 if you never plan to wireless charge the case. But with all of the other changes - better battery life, swipe controls on the AirPods themselves (which is a huge difference, as being able to change the volume directly from the AirPods really is a game changer vs. having to use Siri to change the volume, or pulling out your phone to change the volume), and the U1 (or U2?) chip in the case for better Find My support - there’s really no reason not to spend the extra $20 on the wireless charging version.
Now, if the wired version was a decent amount less expensive, say $100, then they’d definitely be worth a look.
  • Disagree
Reactions: bLackjackj
The extra $20 is a very small premium for conveniences you are likely to appreciate if you use your AirPods regularly. Longer listening time is useful for travel and extended sessions, while swipe volume controls let you make adjustments without reaching for your iPhone or asking Siri
The swipe volume controls are worth $20 by itself - even for someone who might think all of the other stuff as trivial
The 4s did not have these, a feature that I am so used to on my Pros (I mostly save my pro pair specifically for traveling) so as to only use standard AirPods for daily walks and I typically buy a back up pair once a year, when they go on sale for $69 at Walmart and Target 🎯 over black friday
Worth every penny I have the 5’s with swipe controls on the stems and what a difference 👍🏻. Still have my 4’s which I use on my tv for streaming & games.
The lack of a case speaker for Find My on the cheaper model is a deal breaker for me. Were it not for this article I’d missed it. Confirmed on Apple product compare page. I see now that the regular 4’s missed it too, so dodged a bullet when I bought the 4 ANC.
I have never used the volume swipe on any of my Pros, and I've owned all three generations. I just don't find it easy. But the battery and wireless charging features are worth the $20 unless you just use them for short walks and not long commutes/travel.
Both models include Active Noise Cancellation as standard, the H2 chip, the same open-ear design, and the same redesigned acoustic architecture with updated Adaptive EQ. They also share Transparency mode, Adaptive Audio, Conversation Awareness, Personalized Spatial Audio, Voice Isolation, studio-quality audio recording, and IP57 dust, sweat, and water resistance. Both support Live Translation when paired with a compatible iPhone with Apple Intelligence enabled, in supported languages and regions.
The earbuds have identical dimensions and weight. The cases are also the same size, although the Wireless Charging Case is slightly heavier. There are still some notable differences to justify the price difference. Our guide helps to answer the question of how to decide which of these sets of AirPods is best for you.
AirPods 5AirPods 5 With Wireless Charging Case
Force sensorForce sensor with swipe volume controls
Up to four hours of listening time on a single charge with Active Noise Cancellation enabled (up to six hours with noise control off)Up to five hours of listening time on a single charge with Active Noise Cancellation enabled (up to seven hours with noise control off)
Up to 20 hours of listening time with the charging case with Active Noise Cancellation enabledUp to 22 hours of listening time with the charging case with Active Noise Cancellation enabled
Charging Case (USB-C)Wireless Charging Case (USB-C) with support for the Apple Watch charger and Qi-certified chargers
Case speaker for Find My and charging and battery status sounds
Find My with last-connected location and sound playback on the earbudsFind My network tracking, sound playback on the earbuds, separate locations for each earbud and the case, and individual Lost Mode support
Charging case weighs 32.3 grams (1.14 ounces)Charging case weighs 34.7 grams (1.22 ounces)
$129$149
For most people, the AirPods 5 with Wireless Charging Case are clearly the better buy. The extra $20 is a very small premium for conveniences you are likely to appreciate if you use your AirPods regularly. Longer listening time is useful for travel and extended sessions, while swipe volume controls let you make adjustments without reaching for your iPhone or asking Siri.
The higher-end model is worth considering even if you plan to charge exclusively over USB-C. Wireless charging becomes more useful if you already have a Qi charger or Apple Watch charger. Its additional Find My features are valuable if you tend to misplace your AirPods, allowing you to locate the earbuds and case separately and use the Find My network when they are beyond your device's range. The case speaker also helps when it slips between cushions or gets buried in a bag.
The standard AirPods 5 make more sense if you are on a very strict budget, want a secondary pair, or mostly listen for short periods. You still get the same audio technology and noise cancellation, so saving $20 does not mean compromising on those core features. You simply need to be comfortable with USB-C charging, shorter battery life, fewer controls, and more limited Find My functionality.
The charging cases are not interchangeable between the two models. If you buy the standard AirPods 5, you cannot add wireless charging later by purchasing the other model's case, making it worth deciding which features you want before buying.
Before buying, compare prices using our Deals roundup, since discounts can change the price gap between the two models.
If you're considering an upgrade from AirPods 4 or want to see what changed between generations, our AirPods 4 vs. AirPods 5 Buyer's Guide compares the improvements and explains whether upgrading is worthwhile.
Article Link: AirPods 5 vs. AirPods 5 With Wireless Charging Case Buyer's Guide
Although the cheaper ones are still perfectly fine, I do feel like Apple made them as a decoy.
It’s a very common theme in marketing to make a variation that’s not as desirable to push people to the better more expensive version.
The reason I think it’s a decoy is the price difference is only $20.
Most people who only need the cheaper ones will most likely still get the more expensive one’s because it’s only $20 more.
If the price difference was $50 then that would make more sense.
Reactions: turbineseaplane
