possible to put cdma iPhone 4 parts in a 3gs?
Discussion in 'iPhone' started by aPple nErd, May 3, 2013.
  1. aPple nErd macrumors 68030
    aPple nErd
    Feb 12, 2012
    Jailbreaks/IOS Hacks
    #1
    so, would it be possible to put the logic board, screen, digitizer, cameras, and connectors into a 3gs case? just something i have been thinking about
  2. paulbennett95 macrumors 6502a
    paulbennett95
    Aug 30, 2012
    Long Island, NY
    #2
    I'm gonna go out on a limb here and say "no".
    Everything looked REALLY snug inside the iPhone 4S from when I replaced my battery, so each phones case/body is probably perfectly designed to fit its respective components.
    Although I'm sure with enough ingenuity you could make a body that looks like a 3GS but fits the internals of a 4, although I'm sure it wouldn't be as durable, light, or otherwise perfect as the original body is.
    Would be cool to see though.
  3. chumawumba macrumors 6502
    chumawumba
    Aug 9, 2012
    Ask the NSA
    #3
    Even if you succeeded, the 3GS had a sim card slot at the top, and no flash hole, just saying.
  4. Mrbobb macrumors 601
    Aug 27, 2012
    #4
    Anything is possible if you throw enough money at it. Even SIM slot can be relocated. Most of the phone's innards is taken by the battery so if ur willing to live with a smaller capacity battery......
    But the realistic, who would want to go to that kind of trouble answer is, NO.
Share This Page
