Mehka
7
Hi, im having problems with my ipod touch connecting to my office wireless router as it has a index key of 2, any ideas or suggestion on how to connect to it?
can iPT see your network?
what type of security does the network have?
yes i can see the network, my laptop is able to access the router since it can enter key index 2 but im not sure about the ipod touch, WEP key for the network, any solutions?
ok, so when you tried to connect, does iPT pop up a window asking you to input password?
yes, i inputted the password correctly, but nothings showing in safari as the key index is 2
After you said this about sixty times, I decided to Google it, since I've been using WiFi for four years and have never heard this term before. Apparently this index defines how WEP works... 99.9% of people seem not to use it (and the smart ones don't use WEP at all), but it does seem to be a feature that some WEP routers use.
Apple's WEP implementation doesn't seem to support key indices.
So I think you're out of luck.
Also, bumping is boorish and against forum policy.
