Ripping parts of a DVD?
Discussion in 'Mac Apps and Mac App Store' started by scb02, Mar 2, 2012.
  1. scb02 macrumors regular
    Jan 16, 2008
    #1
    Chaps what's the best (preferably free) software where I can rip 1-2 minutes slices off a DVD? Doing a Video CV for a local sportsman who wants certain parts of over 25 DVD's I don't want to go importing every single DVD as he only needs 2-3 mins off each DVD but in various places, what's the best way to go about doing this?
    Thanks
    Simon
  2. simsaladimbamba
    Nov 28, 2010
    located
    #2
    Either use HandBrake and its option to select IN and OUT points via setting the seconds:
    [​IMG]
    or use MPEG Streamclip + QuickTime MPEG-2 Playback Component (19.99 USD or included with Final Cut Studio) to be able to read video DVDs in MPEG Streamclip and then setting IN and OUT marks and then exporting that selection to a format of your choice (better for editing).
    Also know, that using HandBrake will compress the footage further and make it less editable (another transcoding needed for iMovie, FCP and Avid), while using MPEG Streamclip gives you a proper export selection.
    As the source footage is probably not copy-protected, you don't need to rip the DVDs first, if you use MPEG Streamclip.
  3. scb02 thread starter macrumors regular
    Jan 16, 2008
    #3
    Will get MPEG Streamclip and give it a go thanks! Is it quite straight forward on the UI?
  4. simsaladimbamba
    Nov 28, 2010
    located
    #4
    Yes, but maybe have a look at these guides:
    As for setting IN and OUT points, just use the I and O key at the times you want to have that.
    Which editing application do you use? If it is Avid or FCP, you can use JKL and the arrow keys for navigation in MPEG Streamclip.
    As for output settings, it depends on your further steps, but the guides I linked to should give you a bearing.
  5. scb02 thread starter macrumors regular
    Jan 16, 2008
    #5
    Nothing fancy, he's a semi-pro rugby player and wants sections of each game he has done well in, then simple fade between them all with the odd slow motion so probably just do it all in iMovie!
  6. simsaladimbamba
    Nov 28, 2010
    located
    #6
  7. scb02 thread starter macrumors regular
    Jan 16, 2008
    #7
    I do use lion! Could be fun! Will report back.
  8. Rizvi1 macrumors 6502a
    Mar 29, 2006
    Laurel, MD (Baltimore, MD / Washington, DC area)
    #8
    What if you wanted to do this task but with copy-protected DVDs? Would the process then be different?
    I have Lion on my MacBook Pro but my Mac Mini still has Snow Leopard so I can do this on there. Or make a partition on my MBP with SL.
  9. simsaladimbamba
    Nov 28, 2010
    located
    #9
Share This Page
