I was trying to set up my printer (HP 1515) so that I can print to it even when I am not on the LAN, but also using WAN. The airport extreme has now been set up for Bonjour and all that, but the HP printer is connected using an Ethernet cable, NOT USB. It seems the Airport printer sharing is made for connecting a printer to the Airport USB port, and NOT for any ethernet printers.
Is there any way I can print from outside - WAN - to my LAN printer, connected via ethernet to my airport?
I did not find any answer using google or search function here, as all I found assumes it is connected using USB, not ethernet.
Thank you
Thank you
