Guessing you're not booting up Diablo during a flight?..
Only if my flight has onboard Internet to connect to Battlenet and authenticate...
Not to mention the better and cheaper Torchlight 2 game runs just fine on an old HD3000 at 1920x1200 resolution, let alone a HD4000 which is 50% faster.Well unless your flight has onboard Internet to connect to Battlenet and authenticate...
If this ships without a discrete GPU, as it appears it will, it should dispel the notion that the Air isn't capable of driving a Retina Display quickly.
No, it means it's soldered to mainboard and cannot be replacedWhat does unprecedented battery design mean. Longer battery life?
The Air uses a totally different chip.
Just to be clear, the IGP is on-die with the processor. It will probably just use whatever low wattage UM Intel 7 Series PCH is available.The current MacBook Air models run the Ivy Bridge chipset (which includes the Intel HD Graphics 4000 IGP).
This same chipset and IGP would be used with the 13" rMBP since Haswell/HD 5000 is not shipping and I don't see Apple rolling back to Sandy Bridge.
The question remains whether or not Apple will add a discrete GPU in addition to the HD 4000 IGP.
Umm, what'll be the difference besides a slight taper and a bit of weight?
A few hundred MHz is the only significant difference between the entry HD 4000 and one on the fastest quad core.
So it's another computer with the battery glued in with industrial strength glue that ONLY Apple can change, well they'll charge you a fortune because they will just change the entire bottom case.
Low voltage parts are going to get a powerful GT3 variant.That gap is going to get much bigger with Haswell. Intel's reporting 100% speed improvement from HD4000 to full-voltage haswell, whilst low voltage parts are going to make due with only a 30% improvement due to power limitations.
No, Intel wants a monopoly on your logic boards leaving the motherboard manufacturers with little to differentiate their products.Does anyone know if it's possible they'll do what they did with the mid 2010 13"? i.e. a seperate GPU but not totally discrete
AMD has their own quagmire of issues with their own products lines and company. nVidia gave up trying to get a DMI license and went to ARM to diversify.
Easily without a sweat.. Unless you're animator at Pixar, you'll be fine
Buy a console for gaming
Well, yeah. You are fine until you do something involving fancy 3D. The desktop and video playback easy.
I would say Broadwell actually. Haswell seems very incremental to me. Broadwell is supposedly all new architecture.
So how much is thing gonna be? It better be under $2k.
I still doubt this thing can drive a retina only with a HD4000, from what I've seen in the 15" rMBP ...
Uhhhh??
The Air uses a totally different chip. And then there's battery size.
Try again.
