Hi. Here is my dilema _
I have Windows 7 - 64 bit with a I phone 4 and a I touch 16gb.
The I touch needs updating, but i do not want to update it util it sync correctly with i tunes ( which i use for all devices ) as i have an app with data on the device, and i will loose all the data, if i do not sync before i update - GOD DOES THAT MAKE SENSE !!!! ?
But it says i have different apps on itunes, and if i sync this device with ( apps syncd box clikced in the apps tab on the devices section on i tunes ) i will loose the other apps in itunes ie in the main section above i.e. loose the info from my iphone 4
I want to keep the apps on the PC from i phone 4 and add the apps from my touch and use what ones i want on each devices !! ERHGGG
Can someone give me a simple solution, as i cannot phone apple care at this time in the UK, -
Your awaiting a quick reply.
Thanks
Andrew
Thanks
Andrew
