I believe you can legally leave electronics on while flying now! I have left mine on all the time, just put it to sleep.
Depends on the Airline, try using some of the South American Airlines and see what happens
AAC potentially yes (if it's implemented as pass-through rather than blanket transcoding). MP3 no, since it's not supported by the headphones and has to be transcoded to AAC in any case.Apple doesn't support AptX in iOS; however, it is supported in OS X. AptX would re-encode the AAC files to compress them further prior to transmission via the low bandwidth Bluetooth A2DP protocol. In doing so, some distortion in playback of the original AAC file is likely to result--less so than SBC--but some nonetheless. With regards to these Dash wireless headphones though, they support AAC over A2DP natively, so the AAC file can be streamed directly to the headphones without an additional re-compression step. Thus, the audio quality of AAC and MP3 encoded files streamed from an iPhone should be similar to wired headphones
That's indeed a nice feature particularly for runners who don't want to run with their phone.Note, these headphones do support loading custom playlists with AAC and/or MP3 files directly on the headphones themselves albeit only 4GB worth which negates having to stream an audio signal altogether. Still, 4GB is probably enough music for 4 hours of playback time...
After all, once the setup is over, what is any owner of the product going to use them for the most?
get some sort of really slick piercings to make sure they don't fall out of my ears
I need 10 hours of battery life, if they cannot do that then they're useless to me.
I can't picture how or why anyone would need 10 hours per day of non stop use.
a typical 9-5 job + going out + gym / excercise time?
the Job alone is already 7-8 hours. some people spend 1-2 hours at the gym. then whatever additional around the house/ travelling / misc usage.
Its one of the reasons why Wireless headsets aren't really ready to replace wired headsets as the main headset. There is absolutely no batterly life requirement for normal headphones using 3.5mm jack.
There is absolutely battery life concerns when regarding bluetooth wireless headphones.
you have a terrible habit in all your posts to tell others how they should be doing things.I'm sorry this is absolutely atypical of average headphone use.
For someone who actually needs 10+ continuous hours a day, there's BT headphones with 20+ hours of rated use. Your iPhone will give out long before your 10 hour needs anyway. So the headphones are actually the least of it. If someone really has such needs, they're going to be traveling with extended backup batteries anyway to keep their iPhones charged.
And for those where battery life is an actual concern, or where there will be no place to recharge the headphones, or the iPhone for that matter, there are bluetooth headphones with an optional hard wired connection. Just wind that cord around the headphones, and leave it in your bag when going wireless, or plug it in when the battery runs out. Or plug it in where wireless doesn't matter, saving the battery for situations where wireless brings greater convenience. The best of both worlds.
You have breaks, you have lunch time, you have the drive to the gym to recharge them. What else did I miss. Who wears headphones in there ears for 10 straight hours without taking them out.a typical 9-5 job + going out + gym / excercise time?
First, I'd like to point out that the only negative review of the Dash was WSJ. I haven't seen anyone catch on that the pair WSJ tested were either developer or beta with known issues. This was evident by the photos taken and posted by WSJ. The writer's complaints of software could be invalid because he wasn't testing a consumer ready product. Engadget, The Verge, and DC Rainmaker all tested final products at CES. No one has published a reliable outdoor review as of yet. Phew. I feel better by getting that out there.
Glad I am not the only one who noticed.you have a terrible habit in all your posts to tell others how they should be doing things.
"you're holding it wrong"
Am i the only one concerned about the "magnetic induction" part of the Near Field Magnetic Induction technology in terms of my brain health?
Wondering how the intensity of this compares with MRI.. I dont want my brain to be exposed to mini MRI every day.
I do think you are atypical - I am trying to understand a job that has you in a position that you are wearing headphones all day and have no periods in the day when you have to interact with other people. The Dash has a 30 minute recharge time I think with capacity for five charges in the carrying case.
Personally I plan to use my Dash for 30 mins exercise in the morning, then when I get to the office (I currently drive to work) I will wear them whilst working at the computer and then charge them whilst in meetings. AT home I will then use them to watch TV or play on the XBox whilst others are in bed. These are going to be incredible and something I have been chasing to find for 10 years.
So how about we just man up and use ear-clips (like pictured below) instead of trying to act like these aren't a bad idea?
In fact, can we just cut the cord, bulk it up a bit for bluetooth stuff or whatever it needs to work, and sell it?
But, today they have two major shortcomings, price and battery life.
While the charging solution is very clever, for me it does not compensate for the 3 hour battery life. That is just too small and will be a constant inconvenience.
You know what I like about these earbuds? I like how small they are and that they can be recharged in the case. $300 is a little steep to own more than one pair, but how about 4 buds in a case? When two run out of juice, just replace them with the two fully charged ones in the case while the original pair recharge, and are ready when the second pair run out.
I could actually live with that at 3-hours to a charge, but not for $600.
Yes, a cell phone next to an ear for a typical call vs. earbuds in ears for upwards of hours at a time. Yes, that's exactly the same thing. How foolish of me.
These are interesting for sure. As a runner they look very appealing. However, with the Apple watch giving me accurate HR info, plus a pair of $35 chinese wireless bluetooth earbuds, paying another $299 is not in the cards.
