I see all these battery threads with tons of variables. Regardless of workflows, personal use cases, etc the max seems to have about 20-30% ("light use") less battery than it's pro counterpart and up to 50% less on (heavy use). Which the latter can be somewhat justifiable if what you're doing on it also takes less time. (rendering 2 - 30 minute videos in the same time it takes 1 - 30 minute video).
I understand based on the Verge review that Apple has confirmed at a stand still MAX will consume more battery. Which also makes sense.
My question is, will a 14 M1 MAX on low power mode provide the same or close to the same battery life as 14 M1 PRO? and if yes, will it perform at least the same or close to as a M1 PRO? I understand when low power mode is turned on the 120hz is disabled, which isn't a deal breaker when portable, what else is disabled?
All things being equal, if the M1MAX on low power mode performs the same and with as comparable battery life (within 10-15%) of the Pro then it's makes it a much more viable option since if you want the portability you can turn low power mode on and if you need the performance you can either turn it off or plug it in...
