brosenz
351
90
I was able to get:
16" M1 Pro: 10C CPU, 16C GPU 32GB RAM, 1TB SSD
16" M1 Max: 10C CPU, 32C GPU, 64GB RAM, 4TB SSD
I did a lot of measurements over a 24 hours period, both laptops with the initial Monterrey 12.3.1 setup, no additional apps installed, both configured from scratch, brand new, with their respective batteries at 100% charge.
I measured the power consumed at the Power Brick, both using the Apple 87W charger. I used an Emporia Energy meter between the wall and the Apple charger.
The temperature was measured with this device. On the aluminum surface just above the F6 key.
The automatic brightness was disabled and the brightness was set at exactly 50%. Both power settings were set at Low Power. Idle was measured only with Safari open with the www.apple.com website at the home page.
Pro: (average of 50 measurements over many hours)
Idle power consumption: 6.910W
Idle surface temperature: 27.458C
Max: (average of 50 measurements over many hours)
Idle power consumption: 7.239W
Idle surface temperature: 27.817C
Taking into account, manual errors, instrument calibration, and other minor differences, I would say both devices behave very close to each other, at least on power consumption and temperature management.
