dannydifalco
6
7
Just got a 17 Pro max and the keyboard sounds and system sounds are nonexistent. I have the volume (ringer) set to the same as my 16 Pro max and the volume is half as loud. While typing or locking the device i have to put my ear next to the phone to heard the typing or lock sound. Anyone else experiencing this?
Yeah I have the same problem , and don’t have option to turn on/off vibrating in accessibility setting, have zero haptics 😞
Same here. Definitely not as loud or as obnoxious as the iPhone 16 PM ( keyboard clicks ). Figured it was my temporary screen protector blocking the top speaker eairpiece.
Yep make sure the screen protector is aligned properly
The cutout on the top is very important for the top earpiece and stereo speakers
Give them a clean by using a fine brush if it’s too dirty.
Reactions: Fred Zed
I’m
Indeed. I’m using a 16PM screen protector temporarily so makes sense what you said.
that’s ok. 👍 I do use a 14 pro screen protector on my 15 pro too. I plan on getting the privacy one once mines falls apart
What brand screen protector are you using? Mines is avalanche outdoor clothing brand screen protector, non privacy. Just clear
Since iOS 26.2 my keyboard sounds stop working from time to time. I have to reboot my 15 Pro to have them work again.
  • Wow
Reactions: goldmac2006
Running public iOS version? I don’t have that issue on my 15 pro.
Are you using a non Liquid Glass third party app when it stop working?
No idea , it looks the same to me. What’s up with Liquid Glass ?
If a third-party app includes Liquid Glass, it will feature a distinct keyboard with rounded corners, menus, tab bars, and other Liquid Glass elements. However, if these features are absent, it indicates that the app’s UI has not been updated to include Liquid Glass.
Reactions: Yptcn
