Kelmon
733
United Kingdom
Hi Guys,
I hope that someone can either help here or confirm whether this is possible. The scenario is this:
Having become received complaints from my wife's father that the sound quality of a Skype phone call was poor through my PowerBook's built-in microphone. To combat this we bought a Plantronics DSP USB headset last time I was passing through an Apple Store, particularly as it was Skype Certified and came with some free minutes. However, in order to make use of the headset it appears necessary to either change the Skype preferences or open the System Sound Preferences and set the Plantronics Headset as the device to use for sound output/input.
What I'd like to have happen is that the Plantronics headset becomes the sound input/output device as soon as it is connected and that OS X reverts to using the Built-In Audio/Built-In Microphone when it is disconnected. Is this possible?
Additionally, the headset has on the lead a volume controller. While OS X appears to recognise this it only seems to control the Built-In settings rather than the headset's settings. This is odd...
The headset's firmware probably isn't completely compatible with Mac OS X. I've a Logitech headset and have no problems with it, including using the inline controls.
I posted about this not so long ago. I have a Logitech USB headset that I use with Skype. I would like the prefs to change to the headset for both audio in and out as soon as I plug it in, then change back to the built-in mic and speakers when I unplug it. This is part of what the OP is asking about. From what you write, bousozoku, it seems like you've maybe managed this. If so, how?? :confused:
It seems if you first plug in the headset then go to Skype preferences and select USB headset and then quit Skype it is sorted when you next start up.
Hi Guys,
If this is the case then Plantronics are telling porky pies as both the packaging and website claims that the product is Mac OS X compatible and that no drivers are necessary. However, given that the volume control does seem to work as you'd expect it then I can only assume that you aren't far wrong, if at all.
I don't tend to quit Skype but do plug-in/un-plug the headset when needed. I'll give your suggestion a bash when I get home and see if that sorts out the problem with Skype. It doesn't sound like this will resolve the problem in the OS but I can live with that if the Skype issue is resolved. Thanks for the tip.
Interestingly, I've just tripped over a post at MacInTouch.com stating that someone else has observed the same problem as I have with a Plantronics DSP headset but that the problem only began in 10.4.5; prior to this update simply plugging the device in would have the necessary affect. Given this I am now hoping that Apple will release 10.4.6 soon and that it'll resolve this problem.
