Jumpie
macrumors 68020
2,216
1,872
Atlanta
So I was looking forward to using this Anker usb-c 3.0 cable but it doesn't fit with the Apple woven fiber case. You have to remove the case to connect to the MBA. Anyone know of another cable that might work that has 10GBs speeds?
I ran into the same issue with the same cable. I'm currently using this cable for my new iPhone 15 Pro in finewoven case to restore from backup:
So I’m guessing it fits, right? Duh you said you’re using it. 🤦🏼‍♂️
