Sweener88
426
Im EVERYWHERE!
K i have this really annoying problem that bugs the heck outta me! lol
When ever i go to system preferences>desktop and screen saver it ALWAYS goes to the screen saver page first instead of the default Desktop one and as i NEVER even use my screen saver and im constantly changing my desktop background every few days im wondering is there away to change this?! its so annoying lol
thanks alot guys!
Really appreciate it!
thanks alot guys!
I don't think so. . .But is it really that annoying to hit one button? o_o
That said, I'm sure someone has some (non-obvious) fix.
lol yah it really is like i try to keep everything goin as fast as possible and one extra click just bugs the heck outta me as crazy as that sounds lol i think it bugs me mainly because with other user accounts it doesnt do that! argh lol
If you're on the desktop pane and you then quit system preferences, then re-launch it, what pane appears when you go to desktop & screen saver?
For me it opens on the pane I viewed last time.
k i went to it hit back then quit and tried leaving desktop pane open and quitting and it still it goes back to the screen saver one! argh lol
right click (or command click) the desktop and select "change desktop background"
Or use iPhoto to do it.
OR
use JustLooking - an OS X Image Viewer. It can scroll through images, and also set them as a background. It plays animated gifs, and doesn't crash trying to open certain images like Xee does.
I like it. sometimes you'll have to go into sys preferences to change the style it is in (stretch, fill, tile, etc..)
