MacRumors
macrumors bot
70,296
41,914
Following the launch of the AirPods Max this week, Apple has shared a series of support documents with helpful details about the headphones. Apple has also shared some helpful tips on getting started with its new Fitness+ workout service.
How the LED Status Light Works on AirPods Max
On the bottom of the right ear cup of the AirPods Max, there is a small LED status light that serves multiple purposes.
If you press the noise control button when your AirPods Max are connected to power, the status light will turn green if the charge has more than 95% remaining, or amber if the charge has less than or equal to 95% remaining, according to Apple.
If you press the noise control button when your AirPods Max aren't connected to power, Apple says the status light will turn green if the charge has more than 15% remaining, or amber if the charge has less than or equal to 15% remaining.
If you're experiencing issues with your AirPods Max, the headphones can be rebooted by pressing and holding the noise control button and the Digital Crown until the status light flashes amber. You can also reset your AirPods Max to factory settings and unpair them from your iCloud account by pressing and holding the noise control button and the Digital Crown for 15 seconds, until the status light flashes amber, then white.
AirPods Max Aren't Water Resistant
Apple has confirmed that the AirPods Max aren't waterproof or water resistant, advising users to "be careful not to get moisture in any openings." Apple says the headphones can be cleaned with a soft, dry, lint-free cloth, or gently wiped with disinfecting wipes, but the wipes should not be used on the meshed part of the headband or ear cushions.
AirPods Max
Apple Fitness+
Priced at $549, the AirPods Max are available to order on Apple.com, but online orders currently face a lengthy 12-14 week delivery estimate — same-day pickup is also available at select Apple Stores while supplies last. The headphones feature a premium stainless steel design with active noise cancellation, spatial audio, adaptive EQ, and more.
Apple Fitness+ requires iOS 14.3, iPadOS 14.3, watchOS 7.2, and tvOS 14.3 or later. The service is available through a new tab in the Fitness app on iPhone, while iPad users can get the Fitness app from the App Store. On the Apple TV, the Fitness app automatically appears once users install tvOS 14.3. The service requires an Apple Watch Series 3 or later.
Article Link: Apple Shares Helpful Tips for AirPods Max and Fitness+, Confirms AirPods Max Aren't Water Resistant
If there is going to be a cheaper sport version in the future, I’m not surprised that these are not waterproof or water resistant.
Reactions: ohio.emt
How difficult it is to put a rubber gasket on at least some of the openings on the outer body? They must be really finely tuned if there's grounds it could affect performance.
Reactions: innovationwho
Surprised at anyone who thinks that over ear headphones are suitable for any sort of strenuous physical activity.
I use my Bose NC 700 outside all of the time. Especially in Winter I much prefer them to my AirPods Pro as they serve a purpose of keeping my ear's hot in the cold. I don't tend to go for walks with my headphones in the rain but sometimes it starts raining while you are on a walk and having to worry about the headphones taking damage is annoying.
I won't be using them for exercise, I don't expect them to be waterproof. But having IPX4 rating like the Bose NC 700 making you confident that some small shimmer of rain won't ruin them would be nice.
Still can’t get the Apple TV Fitness app to pair with my watch. It immediately says “pairing cancelled” once I select my watch. Even made sure to have the Workout app open on the Watch.
