MacRumors
macrumors bot
70,466
42,156
Bloomberg's Mark Gurman on Thursday reported that Apple is considering launching an all-new 12-inch notebook at the end of 2023 or in early 2024. Gurman said it is unclear if the 12-inch model would be a low-end MacBook or a higher-end MacBook Pro.
Twitter user "Majin Bu" has since claimed that the model will be a new 12-inch MacBook Pro that may be equipped with Apple's next-generation M2 Pro and M2 Max chips. In the MacBook Pro, Gurman said the M2 Max will feature a 12-core CPU and up to a 38-core GPU, while the M1 Max maxes out with a 10-core CPU and a 32-core GPU.
Apple has released both lower-end and higher-end 12-inch notebooks in the past. At the low end, Apple introduced an ultra-thin 12-inch MacBook that weighed just two pounds in 2015, but the notebook was discontinued in 2019. And at the higher end, Apple offered a 12-inch PowerBook G4 in the mid-2000s, prior to the original MacBook Pro.
In any case, Apple silicon chips deliver impressive performance per watt, paving the way for Apple to introduce ultra-portable, high-performance MacBooks without the thermal constraints of Intel processors that the company used over the last decade and a half.
Majin Bu has a hit-or-miss track record with Apple rumors, but he has gained some credibility recently after tweeting that Apple was planning a new 14.1-inch iPad Pro. The rumor has since been backed by very reliable display industry consultant Ross Young, who tweeted that his supply chain sources have confirmed that Apple is indeed planning a new 14.1-inch iPad Pro with a mini-LED display that could launch in 2023.
Article Link: Apple's Rumored 12-Inch MacBook Could Be Pro Model With M2 Pro and M2 Max
Anyway, I am buying a M2 Max in november.
Apple should really name the 12-inch MacBook Air SE.
The 12.4-inch MaBook Air SE with M2 Max Ultra in Midnight.
Rolls right off the tongue!
In all seriousness a 12-inch Pro laptop would be amazing, and a great companion to my current 16 inch for traveling and what not.
  • Haha
Reactions: yitwail
I agree. Not sure why Apple is even calling it the M2 chip. The chip is more like M1 (S). I honestly feel like it was put together very last minute.
It's great for someone making money being trapped in the ecosystem with applications that leverage GPU power under OS X. It's also great for canned benchmarks to show off for marketing.
For everyone else it's wasted die space that sits idle.
Woah, 12" MacBook Pro would be insane, I'd be onboard if it had 120hz + multiple TB4 (both sides) + magsafe. 14" MBP has battery life for days, 12" would be just fine.
That doesn't make any sense does it? The new Pro machines are Pro because they are designed for maximum performance without compromise - so are larger to accommodate better cooling systems and larger batteries.
A 12" MacBook based on them would probably look like the old 12" PowerBook G4s!
I will absolutely buy a new M2-based 12" ultrabook, but I can't see how they make that a Pro-branded laptop. Other than cost of course!
Bad take.
M2 is using A15 cores. The performance is as expected.
You don't put chips like this together last minute. Engineers start planning chips 3-4 years before launch.
