Guys, here's the thing... Note: I am using the iPAD PRO 10.5.
If we want to save more battery we should always let this option enabled. Right?
https://www.imore.com/how-change-auto-lock-your-iphone-and-ipad
However I purchased both the Smart Cover and KHOMO rear case.
So I can use this feature from the Cover:
Wake on open. Sleep on close.
Open the Smart Cover, and iPad magically wakes up. Close it, and iPad automatically goes to sleep.
If I leave the Smart Cover closed (meaning the iPAD sleeping) does that mean I should always disable auto-lock (set to NEVER)?
I don't like the idea of having to press the HOME BUTTON to continue using my iPAD. And I don't need to use any password for it (or Touch ID). Since I can leave the iPAD unprotected and can make it go to sleep by closing the Smart Cover I don't need auto-lock.
Is that correct?
Or if I don't enable auto-lock at all my iPAD will somehow continue to waste battery even if the Smart Cover is closed and the device is not being used?
Is that correct?
