iLOLWUT
75
111
So I've ordered the 8+, I'm currently using a otterbox defender on my 7+, but wanting to go for a battery case this time around for my new 8+
I see battery cases now like the Mophie wireless battery case for the 7+
https://www.apple.com/shop/product/...plus?fnode=99&fs=f=batterycase&fh=458b%2B45bf
With the new wireless charging eventually coming for the 8+, what would be some good battery cases to look into?
Any ideas if the wireless charging would charge the battery case, and the iphone 8+ at the same time? (I know they do this currently via charging from the battery case but not wireless)
What cases/battery cases would potentially benefit from the wireless charging?
Which cases have the best battery life? Seems like most of them have enough for one charge, I'd like to go bigger if possible, but doesn't seem like the 10,000ma will support wireless charging, or at least not yet
Also seems like none of them use the lightning port, only usb, any of them use lightning?
Suggestions???
Also does any one have a recommendation for a blue tooth audio adapter to get if I can't get a case with the lighting port on it?
But the apple battery case is only good for one charge, is there any others with a little more to work with that are comparable?
Apple Battery Case isn't compatible with 8+. I am disappointed they don't have one that fits the 7+/8+. I have one on my 6S and I like it a lot.
Reactions: iLOLWUT
