pjny
798
159
Hi,
I need a reliable usb-c hub for macbook 12 that provides ethernet and usb-a ports and also powers the laptop.
I saw the Macally UC3HUB3GBC USB C Hub Gigabit Ethernet Ports($69) and Cynergy USB C Hub USB 3.1 SD Card Reader Multiport Adapter with USB C Power Delivery for Charging and Multiple 2 Port USB 3.0 Hub Adapter for Macbook 12" ($39)
https://www.amazon.com/Macally-UC3HUB3GBC-Ethernet-Pass-Through-Charging/dp/B01FATU82A
https://www.amazon.com/Cynergy-Ethe...6PU6/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
Anyone use these or can recommend another one? I need it fast so i can transfer images via ethernet from a camera to laptop.
Thanks.
Take a look at the Minix Neo C. Gigabit ethernet, 2 USB A, SD and microSD plus HDMI in a colour matching aluminium enclosure. Gets warm but does the trick. Also has pass thru charging.
I don't have USBc, but I've used Macally products before and found them well-made and functional.
