Franjelisco
86
295
Greece 🏛️☀️🌊
Hello I just bought a battery with the APN 616-0580 but my iPhone's is 616-0579. Is the APN number of any significance? Will I have problems with my battery if I install it on my iPhone? Should I cancel the order? Thank you very much for your time!
What is the APN number in this case? Generally with phones APN is related to the access point name and is related to carrier settings. Not sure what it is in this case.
It means Apple part number. I don't think it matters much if the new battery has a newer part number than the old one. If at all. Since you've already ordered it, and replacing the battery isn't very difficult, I would just install it. Keep the original in case of problems.
