Hello all, I've had my 13-inch macbook pro for nearly 4 years ago and I've been experiencing several charging problems. It's a Mid-2010 model.
The charging problem has occurred a few times before. I guess, from the moment I bought it until today, it has happened 6-7 times? Those times, I thought maybe it has some dust in the charging port because after I cleaned it, it worked. Once it refused to charge because there was a staples stuck in the port.
Anyway, last night the battery was running low at 6%, so I connected the charger. It charged up to 32% and then I noticed it stopped charging. The charging light was off too. I clean again, but it still wasn't charging. Left it alone for a while and try to charge, no luck. I used cotton bud and tissue to really clean whatever were in the port & magsave and it charged! Seriously, it was just normal amount of dirt. Anyway, problem solved.
But tonight, it happened again. Cleaning didn't help. Keep plugging and unplugging the magsafe. When it was connected in a certain way, it charged.
I live in Indonesia (macbook was bought when I was still living in the US) and we don't have an official apple store here, just authorised resellers. There is no genius bar and I'm pretty sure I know more about apple products than the sales people do. Is it safe to say that the problem is with the charger?
Battery Information:
Model Information:
Serial Number: 9G0320930D3MA
Manufacturer: DP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0201
Hardware Revision: 0002
Cell Revision: 0158
Charge Information:
Charge remaining (mAh): 5106
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 5158
Health Information:
Cycle count: 524
Condition: Normal
Battery Installed: Yes
Amperage (mA): 492
Voltage (mV): 12553
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 0
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 16
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 60
Display Sleep Timer (Minutes): 5
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x0085
Serial Number: 0x00abfe98
Charging: Yes
Model Information:
Manufacturer: DP
Pack Lot Code: 0000
PCB Lot Code: 0000
Cell Revision: 0158
Charge Information:
Fully charged: No
Charging: Yes
Health Information:
Cycle count: 524
Condition: Normal
Amperage (mA): 492
Voltage (mV): 12553
AC Power:
Wake On LAN: Yes
Battery Power:
UPS Installed: No
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x0085
Charging: Yes
