fade-
42
Sometimes (maybe once every 20 times i attempt to charge my MBA), on my MBA 2011, when I connect the magsafe and turn on the power plug, the indicator led does not turn on. On my air battery indicator the status shows "(not charging)", but power source shows: "power source:power adaptor"
is this a hardware/wiring/software/lion/user problem? should i be worried? should i send it to apple care?:confused:
thank in advance!
That happens to me sometimes too. I just disconnect and reconnect it and it usually works fine. No idea why it does that, but I think it's pretty common.
thank in advance!
It depends on several things. First, when you plug it in, it may not be securely attached. Also, when it's first plugged in, there may be a short delay before it starts charging. Also, if your battery is already charged at 93% or more, it won't recharge from that point. This should answer most, if not all, of your battery questions:
