I am on the market for a USB-C 4k monitor for MacBook pro 15. Possibly LG 27UK850-w if nothing new and affordable comes out in the near future. LG 5k is way out of budget.
But the power delivered by USB C is only 60w, so I will need to use the Apple 87w charger at the same time. My concern is, will plugging in two power sources be bad for MacBook?
I did some googling yet found nothing conclusive. Some cited from Apple's website that Mac only draws power from one source that provides most power. (But it seems like Apple has taken down this information, which is a little worrying.)
An experiment on YouTube back in 2016 seems to suggest multiple chargers may damage mac and cause battery to stop charging altogether:
Anyone here has a similar setup? How does it work for you?
Thank you!
Thank you!
