Velociwaffle
3
Hey all, just signed up to the forums. Just have a few questions that i hope someone can answer.
1. My power block gets pretty hot. I know thats pretty normal but for a macbook pro how hot should it actually get?
2. My computer also gets pretty hot. I have it on a lap type platform, so its not directly on my lap or bed. It gets hot underneath and above the escape key on top.
3. I often get an error where it stops charging. The screen gets dark and bright over and over. Where it shows your battery life, it shows a message saying (Not Charging). I wasn't sure if this was due to a bad connection from the power cord to the computer(Where it snaps on). Or if it was the power block getting hot or the computer itself.
Image from iStat below(only edited out my ip and what not)
Thanks in advance.
It can get hot enough to make it uncomfortable to touch. It's normal.
Extremely HOT! 85W MagSafe Power Adapter
Superhot Magsafe Charger normal?
Unsafe magsafe plug - almost burned me.
Your temps are perfectly normal, as searching the forum with Google will reveal:
Macbook Pro Heat Dissipation
2010 Macbook Pro 17" i7 heat question
Heat on my i7 Macbook Pro 15"
Macbook overheating?
My Macbook Pro reached 106 degrees !
Macbook pro heat problem
MacBook Pro Over Heat Issue
Macbook pro Hot after 10.6.3. Update
Macbook Pro too HOT!!!
My Macbook Pro Runs Hot
Macbook Pro gets really hot when running windows 7
How hot should my macbook be getting?
Macbook Boiling Hot!
Hot 15" i5 MBP!
MacBook Pro Overheating or That's What I Think It Is?
Macbook pro temperature
MacBook Pro heat causing pain in hands
Alu Macbook vs. 13" Macbook pro: Heat & Battery Life
Etc., etc., etc.
Make sure your connections are secure. Reset the SMC. Make sure your battery is calibrated. This should answer most, if not all, of your battery questions:
Any tips or know a tutorial on how to do these? And thanks very much for the swift response.
Both are listed in the Battery FAQ I posted, under CALIBRATION and CHARGING. I encourage you to read it, as it will answer most of your battery questions.
