Is there anywhere that I can have custom make MacBook parts out of carbon fiber? I don't want just a skin, I want actual parts, I want to fully replace the aluminum body and lid on my MacBook with carbon fiber parts
Um. I would. Or I wouldn't have askedYeah... You're not gonna find anything like that. Who would even give up a perfectly pieced together aluminum body?
In my opinion the heat dissipitating properties don't work too well. At least on mine anyway. It gets pretty hot, and the thermal vents in the hinge are badly placed. As for a price, I know it wouldn't be the cheapest, I've thought of just drilling holes beneath the fan to allow better intake but unless I used a very fine bit and had some screening to apply over the holes to keep things out it'd be a bad idea. I have neither a drill nor the screenI suppose you can find anything, if you show enough money.
What's your budget on that carbon fibre?
Also, if you want to give up on the aluminum, now you have to re-engineer the cooling system - which takes advantage of the heat-sink qualities of the aluminum.
(ActionableMango said it first)
More spin on the fan is something I currently do, I use MacsFancontrol when it gets too unbearably hot (which is more frequent than I'd like) but it only has a bit of effect because of the lack of airflow in the bodyThe aluminum dissipates heat, so it will get warm, even hot. What other result could there be when internal heat is in contact with a good heat conductor? Heat means it is conducting heat out, away from the heat-producing parts. That's something that aluminum is pretty good at doing.
Carbon fiber, by contrast, is a generally a poor conductor, although I read that carbon fiber can be alloyed with graphite or other material to do well with heat conduction. And, if it conducts heat, it will also be warm (even hot)
Drilling extra holes in the aluminum, although it seems like a good idea (better air flow?), but the reality is, that you then have aluminum - with holes, so less aluminum. Aluminum conducts heat better than air. So, unless you add extra air (more fans or faster spin) the cooling would likely be less effective with extra holes, because you have less material (aluminum) in the conducting path.
Outside of finding someone with the capabilities of actually manufacturing the case.Is there anywhere that I can have custom make MacBook parts out of carbon fiber? I don't want just a skin, I want actual parts, I want to fully replace the aluminum body and lid on my MacBook with carbon fiber parts
I doubt it would be possible to accurately replicate the shell simply as one is a machined part allowing much finer/more acute curves and angles. So some compromises to aesthetics is likely IMO
The complexity of attachment of parts (eg logic board) on to the carbon shell. Mounting design of parts on to a carbon body will simply be a different design opposed to a CNC alloy body both for fastener types but also rigidity constraints of components etc
Whilst thermal management for the lower case is a bit of a red herring IMO (for non fanless designs) as it's likely that the Alloy Uni body heat dissipation is only a secondary consideration and probably adds no more than 10-15% to thermal management as usually with fan cooled laptops the bigger concern is to avoid heat transfer to the case bottom and finally on to the users legs for example
Generally controlling heat management via the case would is inefficient, hard to control and spots on the cover external would get hot enough to burn skin.
That's why CPU's etc are thermally controlled via bonded heat spreader with embedded copper heat pipes that bleed heat to a copper heat sink cooled by a fan.
With fan less designs like the rMB there is a copper plate on the bottom of the shell. How much of this is for cooling or to simply avoid hot spots for the user I do not know. A carbon fibre shell is more likely to interfere with heat management in this instance but may appear cooler to the touch.
Mine has a fan, but unless it's put in full time high spin then it essentially has little to no effect on cooling. When it does have any effect, it's noticeable as I can actually bear to sit it on my lap, or on lazy nights in bed on my chest. As for getting an X11 carbon, no. I'm not going to settle for an equally expensive piece of machinery just because I can't have a carbon fiber MacBookJust buy an X1 Carbon
That's the point I made too youMine has a fan, but unless it's put in full time high spin then it essentially has little to no effect on cooling. When it does have any effect, it's noticeable as I can actually bear to sit it on my lap, or on lazy nights in bed on my chest. As for getting an X11 carbon, no. I'm not going to settle for an equally expensive piece of machinery just because I can't have a carbon fiber MacBook
CF is a conductorYou might be better of with a skin because having a non metal body will cause issues because it's not grounded enough, as it relies on the grounding points that touch the conducive aluminum frame
Huh didn't realize that ... well scratch the ground issue, but you still probably will have thermal issues...CF is a conductor![]()
Thermal issues can be solved,either with liquid cooling or extra fans.Huh didn't realize that ... well scratch the ground issue, but you still probably will have thermal issues...
Liquid cooling in a MacBook? Just adds double the size of the whole body and a complete reengineering of the attachments, brackets, screws...Thermal issues can be solved,either with liquid cooling or extra fans.
apart from heat you also have to think about the support for screws and so on with special inlays in the carbon fiber.Thanks for all your responses! I'll definitely have a to think about the 3D printing idea, where I'll be able to get or use a 3 printer big enough to print parts that large I'm not sure, but it's worth a thought!
