I see from various tests that the 14" M1 pro/max run fairly quiet and cool when doing normal load and using the internal monitor only (but get hot/noisy when pushing it -exporting video, using xcode etc with a lot of mulit-tasking/apps open)
Does anyone out there have the new 14" connected to 1 or 2 4k displays? how is the fan noise heat under normal/high load?
I punish my computers with a lot of heavy code compilation, run times and virtual machines, so this is important. My M1 SSD is already 10% worn out from excessive and constant SSD writing by kernel task, presumably because I need so many apps running (including whatsapp/slack/teams/discord/office apps/compilers/windows vms etc). Despite all that heavy work, the M1 macbook is always silent, fans never come on with my 4k display always attached.
Note: I cant get the 16" as I have a bad back and cant lug it around.
