I have 2 eSims active and both work fine in iphone 13. One ATT (USA) and one Vodafone (European). As I started to transfer settings to iPhone 14 I noticed iPhone 14 showed a message that can not transfer Vodafone eSim since the network does not have a number.
It has a number however it is not showing under Settings>Cellular>Sims
I can see ATT number but in Vodafone there is no number listed and field can not be edited. I tested I can dial in and out from the number, caller ID is not blocked. Did all the refreshes and also did a network reset.
What could be the problem? Right now Vodafone is using TMobiles Network in USA. I wonder if it is the issue??
