Hey all.
Like an idiot, I put my Jesus phone in the washing machine, meaning it got very wet.
Long story short, I managed to fix it all, although the screen needed replacing.
Messed around with the new screen, putting it in the phone hundreds of times but it didnt work. Eventually, got another screen, which worked first time, however I get no sound from the ear piece.
The ear piece definately worked after it went through the washing machine, however somehow in the process of disconnecting/reconnecting the Digitizer/LCD, it stopped working.
Also, the light sensor does not work (by that I mean the sensor which tells if the phone is next to your ear or not, and turns the screen off)
The flex cable is definately secured under the white catch.
The phone doesn't think it has headphones in.
Whats going to be the most likely problem, is it going to be the Logik board side, or is it going to be the flex cable on the digitizer side?
Or is it anyones guess?
Thanks for any help!
