Okay, I'm supposed to be specific when describing my problem, so here goes nothing.
Last night, (more than 24 hours ago by now), my macbook took a spill from a counter top, after which it seemed perfectly fine. It was on when it fell, and it continued to be on for some time while I surfed the internet and such like usual until I went to bed, at which point I merely closed the lid, successfully putting it to sleep. It woke up fine in the morning and continued working like a charm until tonight, when, after closing the lid, it did not completely go to sleep. That happens sometimes when I close and then quickly open the macbook, and is easily resolved by re-closing the macbook and/or abusing the escape button a little. This time, however, it would not wake up or finish going to sleep, so I eventually did the forced shutdown thing by holding the power button down. It shut down like it was supposed to, but when I turned it back on, it would not go past the gray screen with the apple logo and the little spinning dots thing. I shut it off and on a couple more times, but to no avail. Next, I turned it on with Alt+Power, and tried loading from there. It lead to the same results, so I put the installation disc in and Alt+Powered again. It did let me load the disc, and that leads me to my first question: What am I supposed to repair? (I'm just assuming this is the best way to proceed. Alternate solutions are also welcome)
Should I:
A. Verify disc
B. Verify disc permissions
C. Repair disc
D. Repair disc permissions
C. some combination of the above.
Also, which disc am I supposed to repair? Is it the one called FUJITSU MHW2120BH Media, or is it the disc that lists the capacity, available, and used space?
Basically, I just want to get it working again without erasing the data that I've got. I haven't tried everything else yet either (booting in safe mode?), but I just wanted some advice before I went wild on the thing.
Finally, I know that it would be a good idea to try and back up some files to another mac, but that probably wont be possible right now.
Thanks,
Luke
Should I:
A. Verify disc
C. Repair disc
Thanks,
Luke
