austriamac
4
Hi,
Just bouhgt a HI-REZ 17" MBP and I have a little problem...
The Hi-rez 1920 X 1200 is cool for Music Programs like Logic, etc but not for reading e-mails, surfing online, etc... When I change the rez to 1280 X 800 to see webcontent, e-mails or any other textfiles in a normal size, its all very, very unsharp!
(on my other laptop, a normal PC, 17", with the rez 1280 X 800, is everything sharp than HD-TV....)
Is there something I can do?
Thanks for ya help!
Regards,
Robin
LCDs only look good at native resolution. Either exchange it or get used to it I guess.
No, LCD displays have a fixed optimum resolution, if you want it to not be so bad, get a CRT, but the LCD works best at its optimum resolution, no less or it will blur because it has to fit 1280 pixels where there should be 1920, and the math doesn't work out on that.
I found that higher resolutions usually just require some time to get used to. Eventually you won't want to go back. Give it some time.
