BradleyGaulden
44
hey i was wondering what the differences are between the entrylevel MBP and the mid range MBPs graphics card?
i know the mid range one is better but i was wondering how much a difference it would make on like casual gaming, like flight simulator or like the sims and stuff like that.....
ps i plan on using my 37 inch Vizio hdtv as an external monitor...
please and thanks to anyone!!!!
:apple::apple:
the difference between the entry level and mid range graphics card is that the entry level has 128 MB of SDRAM while the mid range has 256 MB. While the midrange is a bit better, if it's only casual gaming you won't notice much of a difference.
