val23
34
Hi all,
I have the 2009 Macbook pro 13... everything was working perfectly until now. I came home and plugged in my macbook pro as i usually do, and the GREEN LIGHT is not on, and it says "NOT CHARGING" in the battery indicator. Coconut battery says the AC adapter is plugged in but the battery is not charging. Is there anything I can do to fix this?
Thanks!
Hi all,
Thanks!
Replug, make sure there isn't any kinks in the wire.
This happens to me a lot. I have two different chargers too.
yeah... i tried that.. unplugged (then it goes to battery power).. replugged... still no charge... !! AHH.. i need this for school too..
