Hi,
I have bought a Early 2013 13" macbook pro i7 3.0GHz (A1425)
It had its ssd removed by the place I bought it from.
There is still no ssd inside
Powers on while charger is connected, goes black as soon as you take it out.
I ran it from external ssd and it was running ok, just extremely slow.
I have poped the back cover off and It seems like the battery is connected.
It was probably never disconnected while they were taking the ssd out.
My question is:
*Does SSD not being inside has anything to do with laptop not getting power from battery?
*What connections should i check to make sure it is all connected?
Also
*Is it normal for it to run extremely slow when booting from external drive (16Gb usb2 flash)?
Thanks a lot!
My question is:
Also
Thanks a lot!
