allan_zip
151
Belfast, N. Ireland
Hope someone can help me out.
I'm trying to upgrade the firmware on my Philips dvp630 dvd player. The instructions tell me to write both dvpxx.rom and dvpxxdv.rom files onto a blank cd-r, using the following settings:
File system CD-ROM ISO level 2
Mode 1/2/XA
Character set ISO 9660
Finalised, single session
Write speed slow (eg 2x or 4x)
I have the files and have tried to write a disc in Toast Titanium 6 under the ISO 9660 setting but the disc is not working in the dvd player (tried twice). I'm unclear about the ISO level 2 setting and the mode 1/2/XA setting as neither seem to be options in toast (ISO level 1 is there ok). Can anyone guide me through this or suggest where i might be going wrong.
Thanks in advance.
As far as I know, Finder burns ISO 9660 discs at level 2 by default (as a hybrid with HFS support as an add-on, as a generic multi-platform format). Level 1 is the older DOS compatible format with filenames no longer than 8 characters and a 3 character extension (8.3). Level 2 added 32 character filename support.
You might take some encouragement from this:
I just upgraded the firmware in my Philips 642 ... to 0531. I made the upgrade CD using Mac OS X, burning a disc at 1x with the Finder. As a Mac user, I expect things to work the first time, but I'm
still pleasantly surprised.
No joy. I'm just getting a root directory folder on the data cd menu. :confused:
EDIT: got it working, a third file from the download is meant to be included in the burn despite the instructions stating otherwise.
Thanks for the help, much appreciated.
