VideoNewbie
476
6
im currently running a few programs one of which is virtualbox .
on the activity monitor under "%cpu" i see that it is jumping back and forth from 30-80 %
on the bottom left of the activity monitor though it says %user 2 %system 10
which number should i be concerned about? why is the %cpu for virtualbox so high yet my system % is only 10
does this mean my computer could handle 10 x whatever its doing on virtualbox?
You don't say what Mac you have. Bear in mind that the % CPU figure for each process is PER CORE. So you may find a process running at 110%!
The System % the bottom is the entire value of your whole CPU.
Generally, my advice is not to spend your time monitoring your system unless you have a problem. If you are getting spinning wheels and slowdowns, then yes, look at Activity Monitor.:D
