shamash
595
22
Portland, Oregon
I just got a new Macbook Pro and am typing this from my current Blackbook (2 years old)
I want to transfer over some files.. for instance music and movies. I don't have a firewire cable. How can I do this easily over my wireless network or using an ethernet cable?
Thanks!
The easiest way would be to use Migration Assistant to transfer your data from your black Macbook to your new Macbook Pro :) Ethernet to Ethernet from one computer to the other and away you go....
Or alternatively, if you have a Time Machine backup on your black Macbook, you could mirror your Macbook Pro to be the same as your black Macbook just by doing a Time Machine restore using your restore disc 1 on your Macbook Pro...
