Last night I installed a 1 TB internal drive in my Macbook Pro to complement my SSD (I have no CD drive). 60% of the time, performance is great. The other 40%, it hangs severely and can't read or write anything for several seconds. Does anybody know what could be causing this? For reference, here's what disk usage looks like during a large copy operation (notice it flatlines at 0, even though the copy is still going):
This drive is a Western Digital, but I had the same problem with a 1 TB Samsung a little while back. Samsung told me the drive was defective, but given I'm having the exact same behavior with a different drive, I'm thinking it's not a hardware issue after all.
I formatted the drive with the Mac OS Extended (Journaled) file system. Running repair from disk utility finds no issues. I have tried disabling Apple's Sudden Motion Sensor and disabling Spotlight indexing on the drive. Neither makes a difference.
Temporarily split it into two partitions to run a couple tests, but not planning to keep it that way. Here is what System Profiler reports:
WDC WD10TPVT-00HT5T1:
Capacity: 1 TB (1,000,204,886,016 bytes)
Model: WDC WD10TPVT-00HT5T1
Revision: 01.01A01
Serial Number: WD-WXB1AB0T3611
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk1
Rotational Rate: 5200
Medium Type: Rotational
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
Capacity: 209.7 MB (209,715,200 bytes)
Writable: Yes
BSD Name: disk1s1
Media HD:
Capacity: 386.61 GB (386,612,887,552 bytes)
Available: 99.27 GB (99,267,100,672 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk1s2
Mount Point: /Volumes/Media HD
Media HD 2:
Capacity: 613.11 GB (613,113,806,848 bytes)
Available: 409.97 GB (409,971,826,688 bytes)
Writable: Yes
BSD Name: disk1s3
Mount Point: /Volumes/Media HD 2
Much appreciation in advance for any help.
Revision: 01.01A01
Queue Depth: 32
Removable Media: No
BSD Name: disk1
Volumes:
Writable: Yes
BSD Name: disk1s1
Media HD:
Writable: Yes
BSD Name: disk1s2
Media HD 2:
Writable: Yes
BSD Name: disk1s3
