peshmerga8
10
sweden
Hello guys im new here and this seems to be a good place to get help. My problem is that im having major battery drain! It was at 100% at 23.00 when i went to sleep and when i woke up at 07.00 the battery was dead. Ive been recharching it twice a day and it just drains crazy much battery when on standby. Yes it is jailbroken and overall everything ive got installed is
Zephyr
Installous
SBsettings for NC
DimmedNCBackground
Barrel
Activator
Favorite contact in NC
(NC=notification center)
But I dont really think they would drain it that much cuz ive been the only one with that much of a problem when i googled it. I woul love if I could try and restore it but without updating to 5.1.1 i wanna keep it 5.0.1 and jailbroken/rejailbroken after the restoration. If you have ANY suggestions on what I could do it would help really much.
btw i got 3G turned off, low brightness, location servises off, almost nothing on the notification side on setting (like a red dot called ''notiser'' in swedish dunno in english) overall i got 13 apps on my phone from the app store. got 116 songs and 900 pictures got 10.3 gb availible. running on modemfrimware 1.0.13
any suggestions are welcome Thank you!
Zephyr
Installous
SBsettings for NC
DimmedNCBackground
Barrel
Activator
Yes actually there is...
Just do the steps that i'll give you, and you should notice a difference.
Go to Settings > General > About > Diagnositcs & Usage.
Now just choose Don't Send.
Go back to Settings then do the followings:
- Disable Location Services
- Notifications ( Disable OR modify the settings to manual and disable the apps that you don't want to be notified with)
- Brightness (Adjust the brightness to less than %50, and enable Auto-Brightness )
- iCloud (This is the major issue, Just delete the account)
That should make a difference.
Let me updated. ;)
Let me updated. ;)
Hey mate ive done all of those things now ( had already done most of them just not deleted my icloud account, just deleted it) And im still loosing alot of battery, this doesent seem to be normal and they just relesed 5.1.1 if i have to restore and update i would like to do that to 5.1 not 5.1.1 so if you have any more ideas tell me please!! i have to recharge my iphone like 3 time a day and its annoying!
I guess the problem from your cydia apps,
cuz they'll be running all day,
so try to delete them and see.
Also, updating your iphone to 5.1.1 might solve the problem.
Honestly, I was having troubles with battery by loosing %1 each 10 min!
(my iPhone not jailbroken)
and I updated my iPhone to 5.1.1 then did the steps that I provided, and my problem almost solved. at least I can go 2 days on standby without charging!
Yea ive just been removing everyting i got in cydia only left Sbsettings and IAPCRACKER even tho i dont use it... and i left installous never had a problem from any of those things now lets hope the problem gets solved
Leave it on standby for about an hour
an hour on standby normally won't take more than %1 from your battery.
if you noticed any loosing in the battery more than %2, then the problem not solved yet. :p
lol just left it sitting for 10 minutes and it lost 2%
