Kansas_Vol
3
Hi,
Hoping for instruction/advice: I’m trying to connect a MacBook Pro to a 5.1 surround system. Components are a 2023 MacBook Pro 13” M2, Denon AVVX1400-H receiver that I bought in 2017 and a CalDigit Thunderbolt 4 Pro dock that I bought from Apple yesterday. I tried connecting from the rear headphone jack on the dock to the optical input on the receiver using a Toslink to Mini Toslink digital optical S/PDIf audio cable. System settings seem correct in that it showed TS4 as the speaker output. However, no sound. So, a couple of questions:
1. Are there any system settings that I'm missing?
2. Do I need an external DAC?
3. Will a USB-C to HDMI cable work instead of the Toslink cable?
Thanks in advance for any input!
Are you sure the dock has digital audio out?
It only seems to mention 3.5mm headphone audio out in the specs.
Yes. It has audio-out jacks on the front and back for headphones and one audio-in on the back as well.
But those are analogue only? Not miniTosLink digital?
So yes, you need to connect the Mac to an external digital output device
Thanks PaulD. I thought the newer macs had a built in DAC? Is this not the case?
Yes, Macs do have built-in DACs. DAC means Digital-to-Analog Converter. Analog is something like a pair of headphones connected to the headphone jack. Which of course works.
But you do not want an Analog signal out but a Digital one. Like Toslink / SPDIF. Which MacBooks released after 2010 unfortunately lack.
You are also out of luck with your CalDigit Thunderbolt Station 4:
CalDigit eliminated the Optical Audio connection found on the TS3 Plus and replaced it with the 3.5mm rear audio jack out.
https://9to5mac.com/2022/03/05/caldigit-ts4-review/
What you can do is connect the TS4 dock to your AV Receiver via one of the following two options (which also transmits a video signal):
  • DisplayPort → Active DisplayPort to HDMI adapter → HDMI cable
  • USB-C → HDMI adapter /cable
I suspect the latter would be the most feasible (USB-C → HDMI cable).
Which is also the answer to your question:
I use this one with my Mac which supports up to 4K @60 Hz.
If your receiver/display had Thunderbolt/DisplayPort inputs, additionally the two following options were possible with the TS4 dock:
  • One of the two available Thunderbolt ports
  • DisplayPort 1.4 port
BTW, all of these options are definitely the better solution compared to optical as the latter does not support:
7.1 sound, multichannel LPCM, Dolby Digital Plus, Dolby Atmos, DTS:X or high-definition audio such as Dolby TrueHD and DTS-HD Master Audio.
https://www.the-home-cinema-guide.com/optical-digital-audio.html
