I have a late 2011 15: MacBook Pro hooked up to an external monitor. I know since I am using the Thunderbolt/Mini Display port it is using the dedicated 1GB AMD GFX Card, but the temperatures are crazy. On idle, with no applications open, it overs around 165 degrees. OK, fans are maybe 4,000RPM. I think that is too hot, but can live with it. Here is where it gets weird. If I walk away, and let it sit, not touch the mouse or anything, and let the displays sleep, but not the computer itself sleep, the temperatures are 200, fans are full blast at 6,000RPM. Something is working it hard. CPU usage is like 4-5%, so not CPU. Any ideas? THe laptop is on a glass desk all by itself, no blockage, not running in clamshell mode, the display brightness is at zero the the laptop display is off.
What is causing this hot temps? Thanks
