adam9c1
macrumors 68000
1,906
320
Chicagoland
Hi.
Is there a way to connect iPhone 5s or anything with the 8pin lightning port to some sort of converter cable that will split audio to 3.5mm headphone jack and to provide charge power via USB?
What I purchased now is something like that however it uses a headphone output and it takes lots of force to connect and disconnect.
Not off the top of my head but you could use a 30 pin solution with adapter.
The solution you're looking for would require a DAC.
Have another look.
"This adapter lets you connect devices with a Lightning connector to many of your 30-pin accessories.* Supports analog audio output nd USB audio, as well as syncing and charging. Video output not supported"
Where does the analog come from? The lightning end?
