brendu
Cancelled
2,472
2,703
hey so i have an ibook g4 from late 2003.. it is still using the original battery and i would like to replace it, but i want to make sure whatever i get will be an actual new battery that can hold a charge for several hours. any ideas on best place to look for a battery at best price...
i know apple tends to overcharge for ram and hdd's, is this also true for batteries and is there any other 3rd party perhaps who makes just as good a battery for cheaper?? if not im fine with paying 129 for one because this one is toasted.. lasts about an hour of web browsing
More of the Same
I too had to replace my iBook G4 14" battery a while back (2 years ago) I searched online but most betteries you find are going to be around the same price WITH SHIPPING as if you purchase one at an :apple: store.
So if there is an :apple: store nearby I'd go there, but if not try the "NuPower" that 4JNA posted
Takes a couple of times, but I have used it before. I've also had luck getting a pb battery from a couple of local 3rd party repair shops. They had a couple lying around that used for diagnostic/repair purposes that they didn't need anymore. Charged me $30, but they had 98% original capacity left!
